Another Transfer case neutral lock question
Old Nov 21, 2018 | 06:15 PM
Best4x4's Avatar
“Some” people bypass the interlock all together with a zip tie on the 03-04 models. However it then could get bumped into N or 4Lo easily (which would NOT be good). If you got it to shift out 4Hi it will go into N first then all the way forward is 4Lo.
Old Nov 21, 2018 | 06:51 PM
yardpro's Avatar
Any suggestions on where to access wire to solenoid to test other than removing shifter or from underneath?
Old Nov 21, 2018 | 07:45 PM
Best4x4's Avatar
You remove that assembly from above, remove console, drill out the rivets securing the black plate into position, and then unbolt the 4 bolts securing the 4wd shifter to the black plate.
Old Nov 22, 2018 | 11:08 AM
yardpro's Avatar
That's what I've read.
Was hoping to be able to do it from below... Are least remove the solenoid altogether for now.
Old Nov 22, 2018 | 11:31 AM
Best4x4's Avatar
It's not hard from above, the rivets are the only true PITA, once those are out it's a piece of cake. When re-installing DO NOT use rivets!!! Just use some #14 1/2 screws to resecure the black plate.
Brad S1
Sep 19, 2022 03:25 PM
Wooduck
Apr 19, 2018 10:15 AM
gmad
May 27, 2015 12:11 AM
moorebl
Aug 18, 2013 05:24 PM
dmonares
Aug 7, 2006 01:30 AM
