Another way to fill coolant...
I do not understand where is the clutter; the heater core shutoff is barely larger than the hose, and the in-line thermostat takes the room of the T there. There is no stock thermostat in the engine bay, no bypass hose, instead, now a big void in there with an added bonus of a coolant drain fitted.
---->http://i588.photobucket.com/albums/s...ps980ada81.jpg
The benefits I see, is there is no coolant heat at all constantly flowing into the cabin in summer; and there is no risk of the bypass coolant path to cause overheating if something fails.
Your system looks great, and since you have an older disco, you don't have secondary air injection, hense, less clutter. I have a 2004 and if you've ever looked under the hood of one, there's a big pipe running around the back of the engine blocking access to the coil-pack, there's also large valves on each side of the engine with pipes going down into the exhaust manifold (I think). I'm not sure what secondary air does, but I don't like it always getting in the way.
I personally really like your heater-core shutoff, makes bleeding easier if nothing else. No waterfall sounds. :P
Did a little reading into Secondary Air.
It's just more emissions bull****.
It injects air into the exhaust system just after the manifold, it's literally impossible for engines to run at 100% efficiency (in our case nowhere near) oxygen injection into the exhaust helps combust the remaining hydrocarbons in the exhaust and reduce emissions.
In my own words, it's bull**** taking up a bunch of space in my engine bay because some tree hugging californian said our engines weren't "Green Enough"
Oh yeah, and just in case I've offended someone.
Sorry, but if you're concerned with saving the planet, don't drive petrol V8's. It's that simple.
No offense taken. I have to go hug my tree and cry myself to sleep.
But seriously, I am a bit conflicted. I love my rover/rovers but am also very conscious about the planet. I work for an eco friendly clothing company where we focus on organic cotton and hemp as well as recycled polyester for our yarn content. In addition we use plant based dyes and print all of our media on recycled non bleached paper.
My wife is a nut, we have all sorts of worm bins, compost piles, and various recycling bins in our yard.
So here is the rub:
Is it better to scrap an old car, fill the land fills and create all of the chemical waste that is produced when making a new car... Or is it better to run with an older car, buy used parts and drive responsibly???
I try to live and do what I want while still respecting the earth. If it helps a little to have a secondary air system, I can deal with it. If everybody made a 5% difference in their Carbon Footprint, the earth would be better off.
Now I need to go do burn outs in all of my Rovers and chop down a few hundred trees...
So here is the rub:
When I did my plugs and wires the SAI pipes were without question in the way.
Nothing a universal joint and an extender couldn't handle...
So here is the rub:
So here is the rub:
georgep
10-25-2011 08:29 PM
