Another XYZ Thread
okay current update. ive cleaned the maf with crc maf cleaner and gave it plenty of time to dry. reinstalled the stock ait box with new air filter. drain and filled tranny. i think it getting close to being at the right fluid level. i have the disco up on four jack stands running and im running it through all the gears. allowing the tires to turn and run for a bit. it dose only look like its taken just one galloon of fluid. i did mix the fluid with lucas tranny slip fix but it still seems like there is a hessitation before the tire actually turn. ive clear all the codes and nothing has come back yet. only the three amigos remain. im gonna keep try to get more fluid in it. but is it possible to iver fill these trannys. thanks againfor all the info. ill keep updating this as i go on.
What did the fluid look/smell like that you drained? What kind of fluid you put back in?
See http://api.viglink.com/api/click?for...13242668296671
See https://landroverforums.com/forum/di...e2/#post274862
and pay attention to warning about breaking selector cable at https://landroverforums.com/forum/di...e2/#post274933
okay its been awhile so here my update. i opened up the xyz switch and didnt see much damage or billed up on the contacts. i put it back togeather and just stuck it back on the disco and now it wont start and i have no lights on the transmission selector. any ideas on were to go from here. is m xyz switch dead.
so i got a new to me xyz switch from landroverparts.com my disco was sitting for awhile and i did have to jump start it but it is still giving me the flashing ms lights and the gear selector wont go all the way down to first. did i not install it right or what... please help
