Another XYZ Thread
Old Dec 18, 2011 | 01:57 PM
Dead One Me's Avatar
okay current update. ive cleaned the maf with crc maf cleaner and gave it plenty of time to dry. reinstalled the stock ait box with new air filter. drain and filled tranny. i think it getting close to being at the right fluid level. i have the disco up on four jack stands running and im running it through all the gears. allowing the tires to turn and run for a bit. it dose only look like its taken just one galloon of fluid. i did mix the fluid with lucas tranny slip fix but it still seems like there is a hessitation before the tire actually turn. ive clear all the codes and nothing has come back yet. only the three amigos remain. im gonna keep try to get more fluid in it. but is it possible to iver fill these trannys. thanks againfor all the info. ill keep updating this as i go on.
Old Dec 18, 2011 | 03:16 PM
Snafu / Disco Fries's Avatar
Would be pretty tough to overfill if you were on a level area, unless you were using a fill adapter and a pump...but even then as soon as you took that off to put the plug in it would pour out. I'm not sure if would cause much of an issue either to have a small amount of extra fluid in.
What did the fluid look/smell like that you drained? What kind of fluid you put back in?
Old Dec 18, 2011 | 03:26 PM
the fluid looked alittle dark for only being a day of use. but i used dextron 3 to put back in it.
Old Dec 18, 2011 | 05:05 PM
okay now after running for a bit on the street and m and s lights started flashing. im gonna pull the xyz switch and see if i can rebuild it
Old Dec 18, 2011 | 05:26 PM
Won't need rebuilding, just a really good clean out. There are a series of open contact switches. Ressit temptation to file down their contacts, just clean well.
Old Dec 18, 2011 | 05:36 PM
It makes sense it is a bit dark. You are only getting maybe 1/3 to 1/2 of the old fluid out when you drain. It will take maybe 3 drain/refills to get the fluid to near fully new.
Old Dec 18, 2011 | 09:00 PM
im gonna try and rebuild the xyz switch tommrow and give you guys some more updates
Old Dec 18, 2011 | 09:53 PM
See http://api.viglink.com/api/click?for...13242668296671
See https://landroverforums.com/forum/di...e2/#post274862
and pay attention to warning about breaking selector cable at https://landroverforums.com/forum/di...e2/#post274933
Old Jan 7, 2012 | 09:36 AM
okay its been awhile so here my update. i opened up the xyz switch and didnt see much damage or billed up on the contacts. i put it back togeather and just stuck it back on the disco and now it wont start and i have no lights on the transmission selector. any ideas on were to go from here. is m xyz switch dead.
Old Jan 22, 2012 | 12:22 PM
so i got a new to me xyz switch from landroverparts.com my disco was sitting for awhile and i did have to jump start it but it is still giving me the flashing ms lights and the gear selector wont go all the way down to first. did i not install it right or what... please help
