Anti-Freeze
Old Jan 17, 2014 | 07:59 PM
jalodge's Avatar
Default Anti-Freeze
I need to add some antifreeze because mine is a little low. It is an orange/pink color so I am guessing it is the original O.A.T. antifreeze. I have seen that Dexcool causes a lot of problems. My question is if anyone has tried the hybrid O.A.T. From what I can tell, it has the same benefits as O.A.T. without the problems of clogging.
Old Jan 17, 2014 | 08:11 PM
acamato's Avatar
I am running Peak Global lifetime. It is hard to find in full strength. http://www.peakauto.com/products/ant...full-strength/
Old Jan 17, 2014 | 08:23 PM
jalodge's Avatar
Originally Posted by acamato
I am running Peak Global lifetime. It is hard to find in full strength. PEAK | GLOBAL LIFETIME FULL STRENGTH | Antifreeze / Coolants | Auto Products
I was looking at that one as well due to its compatibility with all types of coolant.
Old Jan 21, 2014 | 11:40 AM
CBRacerX's Avatar
Any reason not to use the pre-dilluted version? I usually get concentrated and mix with distilled water.
Old Jan 22, 2014 | 11:53 AM
acamato's Avatar
when you flush your system there will be water in the system that you can not drain. If you add 50/50 mix to it you will be diluting the mix. I add full strength coolant equal to 1/2 the capacity of the system, then top off with water. This results in a 50/50 mix.
Old Jan 22, 2014 | 12:45 PM
slabrat's Avatar
when you flush your system there will be water in the system that you can not drain .
Pinky Toe flushed his with a leaf blower. I was going to try that but my blower carb died so I used your method. But a leaf blower could work.
Old Jan 22, 2014 | 03:13 PM
acamato's Avatar
I like the leaf blower idea. I flushed mine when I had the radiator out. I just blew into the top hose with my mouth.
turf63
Jul 8, 2010 07:42 PM
ggushee
Nov 21, 2007 03:47 PM
Discochick
Jul 4, 2007 05:15 PM
ggushee
Jun 17, 2007 10:47 AM
37chambers
Aug 22, 2005 10:40 PM
