Any Other Place To Look For Coolent Leaks
Old Feb 23, 2010 | 10:32 AM
SpyderMan1964's Avatar
Default Any Other Place To Look For Coolent Leaks
Guys I had my heads and pressure tested and my freeze plug did not leak. They said they can not do the test with the heads at full engine temp so I had them go ahead and replace them.
While I can get to things with the heads off are there any other places I should look for leaks? I am bummed that I have not found what I would call a smoking gun. The water pump is dry.
Thanks
Old Feb 23, 2010 | 10:39 AM
okdiscoguy's Avatar
throttle body heater plate and front cover
Old Feb 23, 2010 | 10:59 AM
hilltoppersx's Avatar
+1 throttle body heater plate.
Old Feb 23, 2010 | 12:08 PM
Thanks guys I changed the heater plate a few weeks before I pulled the heads. It was leaking but did not fix my problem.
There is coolant that runs threw the front cover? I will check.
Old Feb 23, 2010 | 01:41 PM
okdiscoguy's Avatar
That is how it gets to the water pump.
Old Feb 23, 2010 | 07:14 PM
Valley pan gasket.
Which will need to be replaced since the heads are off anyway.
Spencerfitch
Sep 27, 2020 12:17 PM
FlyingZebra34
Apr 22, 2013 12:07 AM
discoboy
Dec 20, 2012 02:24 AM
Tropical Disco
Oct 27, 2009 12:52 AM
jdthmpsn
Mar 5, 2007 10:58 PM
