Any suggestions on how I splice this wire back together? Picture included ( bad one).
Old Nov 10, 2010 | 02:58 PM
Frank4's Avatar
Default Any suggestions on how I splice this wire back together? Picture included ( bad one).
Getting everything back together after the head gasket job and I just spotted this wire that either got pinched or I cut. It looks like it is a wire in a wire and it goes to a sensor that is on the under side of the block, crankshaft? Knock? Please help!!
Attached Thumbnails Any suggestions on how I splice this wire back together? Picture included ( bad one).-img00020-20101110-1441.jpg
Old Nov 10, 2010 | 04:13 PM
buick215's Avatar
I would solder it and head shrink it.
Old Nov 10, 2010 | 06:27 PM
glenwyatt's Avatar
5th Gear
Default Coax??
Are you saying that you think it's a coax wire?
Old Nov 10, 2010 | 09:13 PM
Frank4's Avatar
I was not sure if that was the right term but yes it is a coax wire.
Old Nov 10, 2010 | 09:30 PM
buick215's Avatar
I don't think it can be a coaxial cable. Coax cables are usually used to transmit radio frequencies. I have never ran into that type of wire in my Land Rover. Hopefully someone else can comment.
Old Nov 10, 2010 | 11:03 PM
Frank4's Avatar
I don't mean that it looks like one that you plug into your tv, but it is similar.
Old Nov 10, 2010 | 11:04 PM
Frank4's Avatar
And you wouldn't know unless you cut it.
Old Nov 11, 2010 | 10:45 AM
glenwyatt's Avatar
5th Gear
I'll be the first to admit that land rover is a little foreign to me, but I have never come across a coax wire on any other vehicle before. I would guess that it is most likely a regular wire which I would just solder and heat-shrink.
BTW- Not all heat-shrink is created equal...You can buy heat-shrink that has a glue which become activated when heated which makes for an awesome repair IMO.
Old Nov 11, 2010 | 11:46 AM
hilltoppersx's Avatar
could be a million things. how bout a picture further out so we can see where it is generally located.
Old Nov 11, 2010 | 11:56 AM
lipadj46's Avatar
I've not seen a wire in a wire yet in a rover. Figure out what it is and consult the wiring diagrams in the Rave.
