Any suggestions on how I splice this wire back together? Picture included ( bad one).
Old Nov 12, 2010 | 12:47 AM
Frank4's Avatar
Hey I know what a wire in a wire looks like and this was a wire IN a WIRE!!! I crimped the inside wire (using a reduced butt connector) and used heat shrink to protect it. I then used some extra copper wire I had in the house and wrapped the already heat shrunk segment making sure that the outside wires from both ends were connected and then used more heat shrink around that . AGAIN YOU WOULD NOT KNOW THIS WIRE IS A COAX TYPE UNLESS YOU CUT IT!!!! THATS WHY YOU HAVE NEVER SEEN IT BEFORE. I am pretty sure this is the knock sensor wire.
Old Nov 12, 2010 | 12:07 PM
glenwyatt's Avatar
5th Gear
Default I stand corrected!!
Upon further research you are indeed correct...some knock sensors do use a shielded wire. I apologise
http://www.dslreports.com/forum/r239...-wiring-repair
Old Nov 12, 2010 | 03:24 PM
lipadj46's Avatar
It's just shielding though, I don't think leaving an inch or 2 of the splice unshielded would matter.
StrutWear
May 13, 2013 03:41 PM
Frank4
Jun 3, 2010 10:58 PM
unstable
Sep 12, 2009 09:33 AM
tee51397
Jun 5, 2008 11:49 AM
