Any thoughts on how to remove this bearing
You don't. just buy a new driveshaft, it's easier trust me. I had a GBR front shaft and tried to rebuild it and I broke broke the flange. I ordered a new one and broke that one too. I would have tried again but I had a ride to go on so I got a new Tom woods shaft (lol).
There's a special tool that pulls them out is the professional answer. A tool I'm the proud owner of now....
Im not sure how long the life expectancy is for the centering ball on any particular drive shaft but I imagine you can save alot of $$$ by just rebuilding the shaft when it is needed rather than replacing the assembly every time the centering ball wears out. A new Tom Woods multiple cardan drive shaft cost $600. Centering ball kit plus u-joints cost less than $100. However without the proper knowledge and proper tools you will likely run into problems while replacing the centering ball. Most notably is the damage that will be caused to the housing while removing the old ball and ring as seen above.
What is this special tool you are referring to? Does it easily remove both the ball and the ring? Im my opinion the ball is easy to remove and easy to replace, its that dam ring thats a bitch.
I used a slide hammer and an inner race puller. I was able to get them as a loner from Pepboys. The inner race puller screws on the the end of the slide hammer.
https://www.pepboys.com/parts/tools/
5 Lb. Slide Hammer
view tool 27033
Pilot Bearing Puller Attachment
view tool 27059
5 Lb. Slide Hammer
view tool 27033
view tool 27059
I agree the ball is the easy part.
Rover Newbie
Jun 22, 2014 11:07 AM
wheelgarage
Oct 1, 2011 03:12 PM
