Any trick to get out of limp mode?
Old Mar 24, 2016 | 02:54 PM
batard's Avatar
Default Any trick to get out of limp mode?
I got the 'ol M and S flashing thing randomly a couple weeks ago. Turned it off and back on and it went away. Now it's back with a vengeance, coming on consistently when I turn it on. I'm pretty sure it's something electrical, like a loose cable or a bad alternator, but I'm looking for a temporary way to get it to shift normally. I tried tricking it by shifting into 3rd then D but no dice. Are there any workarounds on this? I thought I read about one recently but can't seem to find it.
Old Mar 24, 2016 | 03:04 PM
Dave03S's Avatar
Clear the code with a code reader after you start the engine.
Old Mar 24, 2016 | 03:08 PM
batard's Avatar
Thanks, I'll give that a shot.
Old Mar 24, 2016 | 03:48 PM
cappedup's Avatar
If that's your only symptoms, mine was fixed by finding a bad battery connection.
Check both terminals and the other ends are good.
Old Mar 24, 2016 | 04:15 PM
KernowDiscovery's Avatar
^ X2 - a bad battery connection was the culprit on mine.
Old Mar 24, 2016 | 07:12 PM
OffroadFrance's Avatar
In my experience of the infamous M&S flashing lights as long as they are still flashing you are stuck with limp mode until the problem is sorted and the old codes are cleared with a reader.
It can be many things causing the problem mine just happened to be the xyz switch becoming faulty.
Old Mar 24, 2016 | 09:18 PM
LR03NJ's Avatar
I was driving on limp mode for quite sometime before I replaced the xyz switch. My experience, when I shift to R and then drive, the M+S start to flash. Only way I can drive was to turn off then start up again. Look at your shifter, it has to be on D if its blank and you can drive, its the switch. At some point my shifter was balancing between D and 3 to drive it. I need to find the sweet spot. Just hope its an loose electrical cable. the switch is hard to replace in the beginning. My other truck seems having a similar problem now but not sure if its electrical or part of the ignition. Good luck
Old Mar 24, 2016 | 10:56 PM
number9's Avatar
In my case no S&M until backing and then shifting into forward. If a circular drive or when creatively parking would never go into limp.
That's what I did for a at least a month prior to switch R&R. Fortunately was already using a ScanGaugeII, was able to back out of drive and easily clear fault while underway. Sometimes it wasn't a set just pending or not even pending, S&M flashing and obviously in limp.
Bottom line, there are ways to reset/clear fault other than a stop/restart and you'll likely be good to go until S&M/limp again.
Old Mar 24, 2016 | 11:51 PM
JRAM's Avatar
Try this- start the vehicle in neutral and then go right into D. That worked for me until I could refurbish my XYZ switch. Mine was acting up when going from R to D. You will have to key it up first so you can get it out of park.
NinjaPlease!
Jul 31, 2019 09:03 AM
cedward
Jan 3, 2011 04:39 PM
Rickey_240
Apr 2, 2010 05:33 PM
vanhorn2dallas
Mar 15, 2010 11:29 PM
xb70valkarye
Feb 2, 2010 10:13 PM
