anyone with cooling issues, do this first
Old Feb 8, 2010 | 09:52 AM
Mrmerlin's Avatar
Default anyone with cooling issues, do this first
Go to Napa buy a block tester, it costs 50.00 this is the best tool you can have for the Rover.
It is a clear tube that you fill with blue fluid, remove the coolant cap and place the tube into the coolant bottle, start the engine, and watch the tube , do you see bubbles coming through the tube??
If so you have one of these a blown head gasket, cracked head, cracked block.
If the fluid color changes to green or yellow, then you have hydrocarbons leaking into the coolant system and this indicates one of the problems noted above. doing this test will save you money and indicate early problems with the engine.
Old Feb 8, 2010 | 02:37 PM
okdiscoguy's Avatar
seriously man, lay off the block tester sutff, we get it. That is not the first thing to do if you have a coolant issue.
Old Feb 14, 2010 | 11:17 AM
Mrmerlin's Avatar
If you were going to go look at buying a used Rover you should consider taking one of these kits with you, its an easy test and will give you more info about internal engine condition.
Snafu / Disco Fries
Dec 10, 2011 10:03 PM
Cirrus
Feb 6, 2010 01:46 PM
Malave99
Apr 23, 2009 10:34 AM
deadhed106
Apr 29, 2008 03:52 PM
zukman89
Apr 25, 2008 10:21 AM
