Anyone ever replaced the lifters/tappets?
Old Jan 18, 2010 | 01:04 PM
lipadj46's Avatar
Originally Posted by oljohnboy
what is the tool?
http://www.summitracing.com/parts/WMR-W84004
Old Jan 18, 2010 | 01:16 PM
oljohnboy's Avatar
yeah its definitely not an exhaust leak. I have the rave manual, I have been reading it. Has anyone ever known a cap to become loose?
Old Jan 18, 2010 | 01:17 PM
oljohnboy's Avatar
Originally Posted by lipadj46
thanks!
Old Jan 18, 2010 | 02:26 PM
Suede's Avatar
But you have tightened up all 6 downpipe to cat bolts just to be sure. Pretty much all D1's will develop a tick that sounds EXACTLY like a lifter problem, and tightening up those 6 bolts usually solves the problem. If you've already done that as part of your general maintenance, then just ignore me and carry on!
Old Jan 18, 2010 | 04:45 PM
Check your oil pressure first, cold at idle and at 2000 RPM's and warm at idle and 2000 RPM's.
If good then pull the lifter, before replacing, though, check for hardened surface wear on the cam lobes also, if warn, you'll need a cam also, do a 4.6 factory cam if necessary.
You also want to check each push rod fore wear on either end as well as their length, cause they do loose length when wear occurs.
Old Jan 19, 2010 | 06:29 AM
Rovin4life's Avatar
the tool is called a magnet. works wonders with dropped bolts too. just leave the things in oil for a long time along
Old Apr 1, 2014 | 01:45 PM
raeuspius's Avatar
Default r u fn' kiddin me??????????
Originally Posted by XCELLER8
well.......the sad fact is that the lifters wont come out without removing the heads..there wasn't designed enough room to get the lifter through the head, and even if there was the lifter may not just slide out of it's position due to wear on the bottom of the lifter, BUT there is some good news......It may not be a lifter, ( if your heads arent leaking and you dont want to tear into that yet ) I have found that a lot of top end noise is due to years of wear on the rockershafts / rocker arms / and pushrods, on these engines there are only a few thousands of an inch wear between noisy and quiet. I went through basically your same situation a few months ago and ended up replacing the rocker shaft assys and push rods.....now it sounds like a different engine. Remove the valve covers and remove the rockershafts as you were going to do anyway....look them over good and if there are ANY signs of wear its probably time to replace them as well as the push rods. the parts needed are available a lot of places...I got mine from AtlanticBritish.....$300-$400.
Pardon my french but you are a f&cktard weekend warrior oil change kind of guy. (no offense) Pull the intake and then VALLEY PAN then you will know that simply removing the rocker assembly which is... rmove intake, remove rocker cover, remove 4 14mm nuts then allows you to remove the push rods. which allows you to clean up rods and remove suspect tappet. Replace or remove triangular shaped retention clip, remove spring an inspect tappet / lifter for internal wear. you may find that the valley pan / intake manifold gasket allowed WATER to gum up the lifter or you bought a shyte rover that sat for over a year. Pay attention to smell when pulling the rocker cover and if it smells like shelaque <sp? you have a motor that sat without running and you have about 2.5 hours of work and maybe 26.00 in parts... don't forget any fluids NOT 300.. biatch you crazy is what you tell that vulture mechanic. do your research and fix it. don't let anyone touch your landy. PEACE!!!!!!
sdhow
Jan 16, 2015 02:38 PM
mouse
Nov 18, 2014 05:20 AM
Rimmer
Nov 3, 2012 01:13 AM
Cal
Jan 28, 2011 06:06 PM
johnboyairey
Oct 15, 2008 06:16 PM
