anyone found a decent bottle jack that fits in the original spot?
Old Jun 30, 2016 | 09:11 AM
bcolins's Avatar
Default anyone found a decent bottle jack that fits in the original spot?
I never got a jack, or lug wrench with my 03 D2. I bought a Walmart compact floor jack in a plastic case and carry it and a breaker bar and socket. Thinking I would like to find a bottle jack that fits in the original spot. Anyone found one?
Old Jun 30, 2016 | 11:16 AM
CollieRover's Avatar
i just got one from harbor freight, 8 Ton that fits. It did break the rubber strap, but is wedged in very tightly.
Old Jun 30, 2016 | 12:45 PM
Alex_M's Avatar
Torin 2 ton was a perfect fit and works with the strap.
Old Jun 30, 2016 | 01:12 PM
bcolins's Avatar
where did you find that Alex?
My compact floor jack in the case is a Torin,.....from Walmart
Old Jun 30, 2016 | 01:30 PM
jafir's Avatar
Did you guys check that it will actually lift the tire off the ground? The original jack is two stages, and some bottle jacks are not, so just make sure it's got enough extension that you aren't hunting down a 2x4 next time you have a flat on the highway
Old Jun 30, 2016 | 03:22 PM
mln01's Avatar
My replacement jack is a pretty small one and no, it will not lift the tire off the ground by itself. That's why I keep a 10" 2x6 standing up to the outboard side of the battery.
I don't like the fact that aftermarket jacks don't have the saddle at the top of the shaft like the factory jack has. I've seen threads about guys fabricating something but I think it required welding so I haven't bothered. A lot of you guys have welders so go for it.
And for the OP, Paul Grant and others sometimes have original LR jacks for sale but they have such a high failure rate I decided to go with aftermarket. I tried to repair my factory jack and gave up.
Old Jul 2, 2016 | 10:40 AM
Paul Grant's Avatar
From my experience, the D2 jack does have a much higher failure rate than the earlier ones found in DI's and RRC's. I don't know why but I throw away a lot of non functioning D2 jacks (about 25%). It's gotten to the point where I don't even bother trying to add hydraulic jack oil before I toss them. They're just bad and it's a shame because they definitely extend better than most jacks you'll find and have the benefit of the curved saddle REDROVER mentioned.
Old Jul 2, 2016 | 04:34 PM
Alex_M's Avatar
My jack I got on amazon. It's got a top that threads out and it will lift the tire off the ground easily.
Old Jul 3, 2016 | 06:51 PM
NVDiscovery's Avatar
IMO, the engine compartment heat fries them. Store it in one of the rear storage bins.
Old Jul 3, 2016 | 09:14 PM
mln01's Avatar
I agree that's a better place for the jack but my 7-seat truck doesn't have the rear storage bins.
LRlax11
Apr 25, 2015 03:30 AM
aguison
Jan 27, 2013 07:19 PM
maxman
Jul 23, 2011 03:15 PM
meltdowndave
Jun 13, 2008 08:45 PM
meltdowndave
May 31, 2008 01:10 PM
