anyone heard of this chip.
Old May 14, 2014 | 09:46 AM
  #61
SuperSport's Avatar
Just so everyone knows, these have been around for a Long Time. This Performance "Chip" is actually just a resistor. It's a $0.20 resistor from Radio Shack with wires hooked up. They sell from $9.99 - $150.00, depending on how corrupt the seller is. And, the kicker, they are the exact same resistor for EVERY vehicle.
And, ever since people started saying it was just a resistor you could buy everywhere, the more corrupt sellers then changed it and started to use an IC Chip. When in actuality, they only used the Resistor Circuit inside the IC. It only LOOKS different, but it's actually the SAME EXACT thing. Although, it probably costs them $0.25 now.
If bought in bulk (100+), these resistors can be as cheap as $0.02 ea.
If you really want to try this, go and buy a resistor yourself and wire it in following this video tutorial (Show image below to Radio Shack guy to get right resistance). (Remember, this is a SCAM)
For what it's worth, I tried this when I was in my teens. Yes, they were around way back then, I'm now 47 yrs old. I not only lost MPG, but I never saw a gain in performance. Pulled it out shortly after install.
Also, if you look at the disclaimers at the bottom of the website:
Code:
Regarding 10 MPG Gain - * Based on testing performed on a 2012 Toyota Camry. Data
stated is empirical and not a guarantee of similar results.
Regarding 30 HP & 30 FT LBS Gain - † Based on testing performed on a 2009 Mercedes Benz CL63. Data
Regarding Install Time - (They couldn't even get this one right) - ‡ Price reflects installed price by authorized resellers
em·pir·i·cal
emˈpirikəl
adjective
based on, concerned with, or verifiable by observation or experience rather than theory or pure logic.
Original Resistor Type. Still used in MANY of these "Performance Chips":
NEW IC Chip Style. Now costs upwards of $150.00!!! (Tom from CO, I've got some Magic Beans for you):
Resistor Chart - In case you want to try to "TUNE" your chip! Hehehe:
http://physics.ucsd.edu/neurophysics...storcharts.pdf
Attached Thumbnails anyone heard of this chip.-resistor.jpg   anyone heard of this chip.-ic-chip.jpg
Old May 14, 2014 | 12:01 PM
  #62
dusty1's Avatar
maybe, you put it in backwards.
Old May 14, 2014 | 12:48 PM
  #63
Dan7's Avatar
How did we end up with 7 pages of heated debate with zero first-hand experience? There's only so much useful speculation that can go on before we should shut up and await facts about THIS PARTICULAR UNIT.
Old May 14, 2014 | 01:06 PM
  #64
SuperSport's Avatar
That's why I also included a how-to of what to buy for only pennies and test it out. That way, you won't need to bother returning the item.
Here is more info on the mod and where/how to install it:
+20HP POWER SPEED CHIP
Your Mileage May Vary, and your HP, and your Torque, etc...
Old May 14, 2014 | 02:46 PM
  #65
acg's Avatar
acg
Talking
I swear... the chip improved my mpg, solved my cooling issue, CDL appeared as an option, truck raised itself by a couple of inches, the driveline whine went away, the rear subwoofer sounded better, the 3 Amigos went back to Mexico, the SRS light went poofed..... and my love life improved (aka the Disco became a chick magnet from some reason)
Old May 14, 2014 | 04:22 PM
  #66
Dane!'s Avatar
Are you sure? Did you try turning it off and then back on again? I'm sure that was your problem
bvm
Dec 9, 2010 12:50 PM
HelenaRover
Sep 22, 2010 01:29 PM
jycsalas
Sep 10, 2008 01:04 AM
bigugly82
Dec 6, 2006 03:08 AM
