anyone mounted a jerry can to the spare tire?
Old May 10, 2010 | 05:20 PM
03discoman's Avatar
Default anyone mounted a jerry can to the spare tire?
anyone done this?
how did they do it?
i searched already...nothing came up
Old May 10, 2010 | 05:23 PM
dnorrell's Avatar
Columbia Overland has one option here. Nate Bottorf of Bottorf manufacturing also makes a tire carrier that features a modular fuel can carrier. You just pop out the center cap of the spare, slide in the fuel can carrier in the now-visible receptacle, retain with a pin, and you are done. Remove when not needed.
Old May 10, 2010 | 09:51 PM
hunter's Avatar
Does the extra 41lbs of weight excessively strain the door hinges? Deciding between roof mounting and this option too.
--------04 SE7
Old May 10, 2010 | 10:34 PM
dnorrell's Avatar
I have been told it won't be a problem, but I can't speak from experience yet. Hopefully someone else will chime in.
Old May 10, 2010 | 11:32 PM
handsome rob's Avatar
I have not done it myslef but I have some thoughts on it. I guess it will boil down to what you really plan on doing.
If you left it on there filled all the way for a long time period then it could cuase some sagging of the door. If you did it while just on off road trips then it would not be a constant weight and can last a while. The other option is if you are just going to keep it part way full so you can make it to a gas station it should be able to handle the weight all the time.
Good Luck with it.
Old May 11, 2010 | 12:12 PM
Suede's Avatar
Another option, if you're handy, is to make some minor modifications to the Blitz Can Carrier.
Last edited by Suede; May 11, 2010 at 01:20 PM. Reason: Located a Disco Specific Mount Below
Old May 11, 2010 | 12:17 PM
okdiscoguy's Avatar
It is a strain on the hinges if the door is opened while the can is mounted. Many of the Camel tropy trucks had problems with the hinges because people would stand on the spare with the door open.
Old May 11, 2010 | 12:21 PM
Exactly! But with the weight only being about 45 lbs it would not be as bad. Like I said in my post, if you just carry a couple of gallons to make it to a gas station then you are probably okay, extended use of it while full is probably not the best idea.
Old May 11, 2010 | 12:46 PM
salve7's Avatar
I replaced the rear tire carrier with a jerry can holder because I don't mind having the spare in the back but there is no way I would drive with gas in the cabin. Another option would be a smaller, 1/2 gal size that would be enough to get you to the gas station but not enough to weigh anything. I would also imagine that if you were just riding around with a partially filled can, condensation could be more of an issue. I also found this the other day but I'm not sure how they would work with our set up. Maybe reverse the spare? I don't have a website just a pic borrowed from another forum. It is commonly found with the mercedes.
Attached Thumbnails anyone mounted a jerry can to the spare tire?-g280-explorer-7.jpg
Old May 11, 2010 | 01:15 PM
Suede's Avatar
Found one that's Disco Specific from Columbia Rovers:
$100 picked up, or $115 to your door.
Call Josh at Columbia Rovers in Portland -- 503.227.3766
