Anyone try this on a Disco?
Old Jan 29, 2016 | 11:41 AM
jamieb's Avatar
Default Anyone try this on a Disco?
I made one of these for a Volvo 870 I used to own. Basically just build it, put fluid in it, screw the cap on the reservoir, pump it up lightly. I used a stick to hold the pedal down. At the wheel I had a tube going into a bottle with fluid and all I did was crack the bleed screw, fluid would flow and when I saw no bubbles, close the screw. Move on to next wheel.
Any thoughts?
The DIY $20 brake bleeder
Old Jan 29, 2016 | 11:48 AM
drowssap's Avatar
yes i believe 04duxlr posted p[ix of one he made
Old Jan 29, 2016 | 11:55 AM
04duxlr's Avatar
I've used that setup on mine but for me by far the easiest way to bleed the brakes was with speed bleeders. If you haven't heard of them, they are a bleeder screw with a spring-loaded check valve in them. You crack the bleeder and just push on the pedal and out comes the fluid. The check valve seals it up when the pedal returns so no air is drawn in. I use them for fluid changes too. Some people have had problems with them quickly corroding up and becoming useless but I haven't had that issue and I installed them several years ago. Just the same, you could install them, bleed the brakes, then swap them out for the original bleeders if you wanted. I will have to see if I can find what part numbers I used.
Old Jan 29, 2016 | 01:33 PM
jamieb's Avatar
Just bought a reservoir cap for a Disco II for $10 and decided to make one myself. Partly because I may not have my wife/son at the time, partly because I just wanted to make one. :-)
Fenix
Feb 15, 2015 12:13 PM
Big Jim Swade
Dec 16, 2011 10:47 PM
Jason_B
Dec 16, 2009 09:46 AM
christians1600
Jul 28, 2008 09:58 AM
