ARP Studs, what torque to you stop at?
Old Mar 8, 2021 | 09:57 PM
Wargoob's Avatar
4th Gear
Default Im curious how your heads are holding up?
How did 70 lbs work out? I'm having an antifreeze leak at 70 lbs.....
Old Mar 9, 2021 | 12:30 AM
Richard Gallant's Avatar
70 worked well for me a year later zero issues
Old Mar 9, 2021 | 12:40 AM
Wargoob's Avatar
4th Gear
That is awesome to hear. I have a antifreeze leak on the back of the head... I increased the torque on the head bolts on the outside of that bank to 80 ft lbs. Hopefully that takes care of it. If not I will just add some stop leak. Thanks
Old Mar 9, 2021 | 09:20 AM
Roby466's Avatar
Default Still holding up
No antifreeze leak on mine.
I followed the ARP provided guide and all is good.
I had the heads skimmed and I only scraped the block with a plastic razor blade (I know, it’s not a razor blade if it’s plastic but it looks like one) and rough rags and cleaner until fully clean. No scotch brite pad or anything else abrasive.
I did order the better headgaskets from AB after seeing the one I had appeared cheap.
my rocker covers however . I retightened those yesterday as I was getting the oily drip on the exhaust manifolds.
Old Mar 9, 2021 | 09:59 AM
Wargoob's Avatar
4th Gear
Default Nice
i used abrasive pads to clean up the block... maybe thats where I went wrong...
Old Mar 9, 2021 | 10:04 AM
whowa004's Avatar
Unless you went crazy with the pads you will be fine..
Old Mar 9, 2021 | 12:05 PM
No Doubt's Avatar
81 lbs is still working for me. No problems.
Old Mar 9, 2021 | 12:39 PM
@Wargoob More likely it is the lower intake gasket, if you pop the upper off you can inspect
Old Mar 13, 2021 | 01:53 PM
XRAD's Avatar
Yep, I have not been impressed with any of the aftermarket intake gaskets. places to leak coolant...they do not fit the runners well, especially the AB one....they a re a bit too long side to side....and I think it's more than just skimming the heads a few thou...these gaskets are off by 5mm...
Old Mar 14, 2021 | 06:21 AM
Roby466's Avatar
I had received the Victor Reinz in my kit and it didn’t inspire confidence. I ordered the AB preformed valley pan gasket and that worked. Coolant could be leaking there. I used a very thin layer of VR sealer around the coolant passages on the underside of the gasket only.
gulfdisco
Apr 11, 2020 03:03 PM
Alex_M
Jul 25, 2018 03:36 PM
gulfdisco
Jan 31, 2017 08:26 AM
CANAMDiscovery
Apr 22, 2013 08:34 AM
Willie00d2
Feb 25, 2013 02:56 PM
