Auto shifting, stalling, steering pump issues...
Howdy all,
Just bought a 2001 Discovery II that had been sitting for a long long time. I've discovered a few issues that I don't know if related...
At startup the steering pump sometimes makes a knocking sound that usually goes away after a few minutes, intermittent heavy steering... (already have a replacement lined up)
Occasional low speed stalling, ex: parking lot maneuvering. Possibly related to steering pump?
Intermittently not shifting from 2nd to 3rd in "D". Will rev up to 4-5k and not shift. If I shift lever down to "3" it works fine. I will sometimes shift it back up to "D" and it seems to work fine... I'm planning a Trans oil change using Atlantic British's trans oil kit to see if it helps... Hoping it's not a sensor or other issue...
It of course has the 3 Amigos party going on but when I stopped at Vatozone to have the codes read, the only code was the "needs MAF replaced" code... WTF?
Which reminds me,the air filter and MAF sensor were filthy and full of leaf debris and I was surprised it even ran with how clogged it was.
Apologies for the lengthy post, TIA
Howdy all,
Don't bother doing the option b fix until you read the ABS codes. A lot of free shops don't have the code reader specific to the ABS system. I have an Autel A619 reader which does everything for every vehicle, there are other options from Hawkeye etc.. Start with finding out which codes are in your ABS computer. You might have to do option b, you might just need a wheel speed sensor.
Firstly, use the A&B part numbers and check prices on Amazon, LRDirect, or Lucky8. I have found EVERYTHING they offer for cheaper and free shipping.
Secondly, Try the Bosch MAF and see what happens
Thirdly, Get the iCarsoft LR II for your Land Rover so you can read and delete your own codes. If you can't delete the codes, they don't magically go away after replacing the part.
I think this was for my thread. I will get the IAC off when it is not bone chilling cold and inspect.
