Autozone has techron buy 1 get 1
Old 06-13-2010, 08:00 AM
lipadj46's Avatar
Default Autozone has techron buy 1 get 1
Good time to buy a couple bottles of techron to dump in the tank.
Old 06-13-2010, 08:52 AM
That is a good deal, Techron is better the Seafoam when it comes to a gas additive. By the way was that for the large or small bottles?
Old 06-13-2010, 09:45 AM
lipadj46's Avatar
The small 10 oz bottle that treats 10 gallons. I see techron has a new 10 oz bottle that treats 15 gallons so maybe autozone is trying to move the old stuff out.
Old 06-13-2010, 10:03 AM
Thanks for checking, I used to use the lagre bottles that handled 20 plus gallons, may have to go check this out.
Old 06-13-2010, 11:41 AM
lipadj46's Avatar
I usually double dose so I dumped in 4, 10 ounce bottles and filled it up. I do this twice a year.
Old 06-13-2010, 12:40 PM
buick215's Avatar
When you use Techron do you run the risk of fouling up the spark plugs like Seafoam.
Old 06-13-2010, 01:33 PM
lipadj46's Avatar
No techron has Polyethylamine in it which is the same detergent used in modern gasoline just in much higher doses. Seafoam really is not a fuel injector cleaner. It is an upper cylinder lube and can be used to get moisture out of your fuel system. You are talking about running seafoam through the intake which is different anyways.
Old 06-13-2010, 03:22 PM
This is a good deal for those who need it.
It has been my experience that as long as you use good brand gas you dont need a injector cleaner.
No it wont hurt, but it might also be a waste of money too.
hilltoppersx
ROAMING WITH FRIENDS
02-03-2012 10:53 AM
casanova00
07-28-2008 10:57 PM
starcraft
05-21-2008 01:23 PM
nynole
02-16-2008 06:14 PM
OxyCoRover
01-23-2008 09:00 AM
Quick Reply: Autozone has techron buy 1 get 1
