Auxiliary Light Wiring Harness
Old Apr 21, 2025 | 12:10 PM
Discoidiot's Avatar
Originally Posted by disco96sd
I have a complete NOS D1 wiring kit for auxiliary lights - when I bought my 96 D1 I was going to put a safari roof rack and auxiliary lights on but found out that it would be too tall to get into my work parking structure - the dealership took the rack and lights back after it was ordered but wouldn't take the wiring kit - not sure if this would work for a D2 or be of interest ?
This sounds great for anyone interested. Can you post some pics of the parts or box or whatever you have? If I remember correctly, the D1 binnacle switches are more of a "gray" than the D2 "black" switches. I'd love to keep everything looking stock.
Old Apr 21, 2025 | 12:22 PM
Discoidiot's Avatar
Originally Posted by Jensen Vermont Stenberg
Check out this s thread.
https://landroverforums.com/forum/di...e-my-d2-68943/
The s13 plug can hold a standard crimp on blade connector. You can run the wire through the firewall grommet on the passenger side. You can use it as power, but I’m using it for a signal to turn on my relay box. If you’re gonna run a bunch of lights and other accessories, these are pretty tidy.
https://a.co/d/glst4S0
can stick it anywhere and only need to run one set of wires to the dash to the control panel. All other wires can terminate under the hood or wherever you mount the relay box.
ooooooooo - that S13 plug looks super interesting....
Old Apr 21, 2025 | 09:53 PM
gecko951's Avatar
If you don't already have one...get a "wire insertion tool" to make it easier to feed wires through the firewall grommet because doing it with a screwdriver or a standard wire fish is a pita.
Old Apr 27, 2025 | 06:53 PM
Discoidiot's Avatar
Originally Posted by gecko951
Something like this should work for you and its good for up to 300W: https://www.amazon.com/Nilight-LED-L...dp/B0948V5R5J?
OK, I bought that Amazon Nilight kit and it's actually a decent quality. Of course, it doesn't work with the Disco switch. I've wiring pin 4 to chassis ground, pin 1 to relay ground, pin 2 to positive (which makes the Disco switch light up) and Pin 5 to switched leg.
What I'm realizing is that the Disco 2 latching cruise control switch completes a ground between pin 1 and 3/4. The Nilight switch/relay is wired for 12v+ switch.
Without being a wiring/electrical guru - can I just switch wiring at the relay and make this setup work? Or do I need a different relay?
Old Apr 27, 2025 | 07:26 PM
rikkd's Avatar
I'm not sure, but please post the results of what you do! I'm interesting in doing something similar.
Old Apr 27, 2025 | 07:36 PM
gecko951's Avatar
I don't think you need a different relay, here is a post and diagram that should help.
https://discoweb.org/index.php?threa...-lights.32294/
redrover75
Oct 23, 2020 08:25 PM
Ben Matheson
Apr 14, 2019 04:24 PM
Tercan
May 2, 2010 09:24 AM
tornado_735
Apr 27, 2009 08:25 AM
Coovie
Mar 11, 2006 02:51 PM
