On average, how long do crankshaft postion sensor last?
Old Mar 28, 2019 | 03:15 PM
  #21
CollieRover's Avatar
My intermotor lasted a year or so, maybe less. I'll never put in another non-Bosch sensor on the motor.
Old May 9, 2021 | 10:55 AM
  #22
Paul Grazal's Avatar
Default Crankshaft and cam shaft sensors
its not so much the miles. Its more about heat and time taking its toll on the strength of the magnet. At 10 years you should get both cam and crank replaced IMO to avoid any failures that leave you stranded
Originally Posted by earlyrover
2004 LR Discovery, 110.000 MILES. Regarding the crankshaft position sensor, which when faulty, causes the ECU to not receive pulses from this sensor, so the ECU allows fuel ejectors and/or ignition spark timing to be lost, thus vehicle engine does not run, and when engine does stop, it cannot be started again, until engine gets cold. At least this was my experience with bad sensor, though it may cause other conditions as well. My bad sensor was a Bosch, and I THINK OEM, (WHICH BECAME BAD AT 110,000 MILES) because it said on it that it was made in Germany, while in more recent years. most Bosch examples I have seen say that they were made in Romania. Having this sensor die on you, especially when you are many miles into the most remote areas possible, does not lend itself to your personal security. DOES ANYONE KNOW, IN GENERAL, THE LIFE EXPECTANCY OF THESE BOSCH CRANKSHAFT POSITION SENSORS? AM I CORRECT, IN THINKING THAT THEY MAY LAST AROUND 100,000 MILES, IF MY ANALYSIS IS CORRECT, OR AM I WAY OFF WITH WHAT I THINK IS AN EDUCATED GUESS? PLEASE SHARE WITH ME, AND OTHER READERS, YOUR EXPERIENCES WITH FAULTY BOSCH CRANKSHAFT POSITION SENSORS.
Old May 9, 2021 | 12:32 PM
  #23
Best4x4's Avatar
The Bosch units last a very longtime. It all depends if the original heat shield is still in place or not. Non Bosch DO NOT last long at all.
Old May 9, 2021 | 06:08 PM
  #24
Extinct's Avatar
All depends on the heat shield. Should last indefinitely with a proper heat shield, I wrap mine in aluminum foil.
SundayFunday
Sep 3, 2019 05:38 PM
aarons02
Apr 28, 2013 07:45 AM
bham01D2
Aug 7, 2010 07:53 PM
Outback Jim
Jun 22, 2010 09:14 AM
