Axle Hud Repair and Pads Question.
Old Feb 26, 2010 | 09:26 PM
mwindth's Avatar
Default Axle Hud Repair and Pads Question.
I know that there are there are 2 seals, one inside the hub and an an o-ring between the hub and the axle. I will figure out which one to replace once I get it apart. Hopefully it is the o-ring.
But my question though concerns the pads. I know I can just clean the rotor and replace the pads. These pads and rotors only have 10K on them; all OEM. Do you think it is alright to replace just the pads on the side of the rover with the axle leak? Or do I need to replace the pads on both sides for even wear? Even at 10K miles the pads look almost brand new with a lot of wear left on them. It is the rear passenger side axle with the leak.
Old Feb 27, 2010 | 02:02 PM
mwindth's Avatar
Never mind...I just found out you can only buy pads in pairs of both left and right. Looks like I will have a little more work to do.
Old Feb 27, 2010 | 07:04 PM
It is always a good idea to replace wear items like brakes in pairs.
OffroadFrance
Jul 24, 2015 03:00 PM
OffroadFrance
Mar 6, 2015 09:27 AM
Racer X
Off Topic
Apr 9, 2014 10:37 AM
cationmoted
Oct 19, 2012 07:39 AM
ljdiscovery
Jan 17, 2009 01:35 PM
