Axle not centered after 2” lift. Adjustable panhard bar needed?
Old Dec 29, 2023 | 05:08 PM
vitz's Avatar
Default Axle not centered after 2” lift. Adjustable panhard bar needed?
Put a 2” lift on my D2. When I went to put on my 255/70r18 tires (which should fit after extensive research) I come to find the passenger side hub sits a lot more forward than the driver side. The tire won’t fit the passenger side lower rear bumper while the driver side clears no problem.
will an adjustable panhard bar fix this and bring the axle in line with itself? See attached photo for dramatic reference. If so was also going to replace the steering dampener as well. Any thing else I should take care of?
Old Dec 30, 2023 | 01:37 AM
Dervish's Avatar
Panhard wil locate the axle sideways, not front to back.
How are the bushes on the trailing/towing arms?
Old Dec 30, 2023 | 09:34 PM
vitz's Avatar
I’ll take a look at the bushings. Thanks for the suggestion. Leaning more toward my bumper being more tweaked than I thought. Might have to go aftermarket to solve this issue if the alignment checks out ok.
Old Dec 31, 2023 | 01:55 AM
JohnZo's Avatar
One of my trucks is like that because the PO banged into a snow bank on the right.
Discotime1
Jul 9, 2022 12:21 PM
cybercop
Mar 22, 2021 11:18 AM
raul507
Jun 6, 2019 03:05 AM
vette427sbc
Dec 25, 2014 01:58 PM
vette427sbc
Sep 11, 2014 11:37 PM
