Axle nut
Old Oct 22, 2024 | 10:14 PM
miron's Avatar
Default Axle nut
Ok so, this is a probably a very dumb question, but is the passenger side axle nut reverse threaded? It looks to be normal left hand thing, I already snapped one 1/2" braker bar on it, so I'd like to eliminate my ignorance before i brake another one
I did read older posts but no mention of thread type...
Nvm just had to go with 3/4" bar and 32mm socket...
Old Oct 23, 2024 | 03:00 PM
Harvlr's Avatar
I haven’t done one on the D2 yet, but on a Dakota I had, I broke 2or 3 sockets trying to remove the axle nut. They’re really tight. Your 3/4” bar and an impact socket should work.
Old Oct 23, 2024 | 07:23 PM
rikkd's Avatar
I bent a cheater bar and snapped a breaker bar trying to get it off. Try and pry out the push tabs, and spray with PB-Blaster/WD-40m. I had luck trying to tighten it a bit to break it loose then turn it left.
Old Oct 23, 2024 | 10:54 PM
miron's Avatar
For real...as if those nuts were actually holding something that's about to fly off
Old Oct 24, 2024 | 02:48 PM
Harvlr's Avatar
It seems to work, I haven’t heard of them flying off😂
Old Oct 24, 2024 | 02:58 PM
miron's Avatar
Right these are def not coming of on accident, but even if they did, what else would?
SouthByWest
Mar 16, 2023 04:01 PM
DakotaTravler
Oct 13, 2018 12:30 PM
LADEROUTE
Feb 11, 2015 07:52 PM
ZGPhoto
Apr 9, 2013 01:52 PM
ajh
Nov 9, 2007 06:49 PM
