Axle seals...
Old Aug 10, 2022 | 05:18 PM
dtmbinb's Avatar
Default Axle seals...
About to do some front end maintenance. New rotors, pads, calipers, hubs, and ball joints. I assume I should replace the axle seals as well, correct? Thanks for any insight.
Old Aug 10, 2022 | 11:19 PM
nashvegas's Avatar
I would not have said this until about the last month - but perhaps do the axle seals if you're doing ball joints.
Here's why: I just replaced (at a shop) 4 ball joints on mine, and a month and 500 miles later, the LF axle seal is leaking badly (all over the wheel, tire, wheel well.. I would 100% bet it's due to all the hammering / banging around to get the ball joints replaced.
Old Aug 11, 2022 | 08:35 AM
dtmbinb's Avatar
That's what I'm thinking.
Old Aug 11, 2022 | 04:13 PM
Brandon318's Avatar
It's more just that the axles get removed during the process, which affects the seals. Sometimes they're fine, just depends on the age and condition of the seals. I didn't replace them on my 2004 when I did the ball joints and they never started leaking after, but they were only 85,000 miles old at the time. I will say, it's way easier to do with the steering knuckle removed, so if you're gonna do them, now's a good time. BUT, get the best seals you can buy so you don't have to do them again. Cheap seals will leak.
Old Aug 11, 2022 | 05:48 PM
dtmbinb's Avatar
Just ordered Genuine LR seals today. Thanks.
Brandon318
Jul 24, 2020 11:27 AM
FlyingZebra34
Sep 21, 2013 01:31 PM
tweakrover
Oct 12, 2011 11:03 PM
GROVERtheROVER
Aug 29, 2011 09:37 PM
Luky
Jul 17, 2009 08:32 AM
