Axle Strength
Old Mar 28, 2021 | 08:30 AM
SundayFunday's Avatar
Default Axle Strength
Has anyone ever broken an axle shaft?
Overlanding, black diamond off roading, towing, climbing, what have you... Just wondering if anyone’s real world experience has left you with an axle shaft or CV failure.
I’m finding the stock shafts are rated up around 3000-3500 ft/lbs
Old Mar 28, 2021 | 10:20 AM
Xanthro's Avatar
Yes, it can happen. Especially, if you install lockers and don't upgrade to stronger axels. I've been on trips whece people even carried space axels.
You really have to push stock axels to break them, it's not going to happen on any standard trip.
Old Mar 28, 2021 | 10:46 AM
Alex_M's Avatar
Spider gears will probably let go before the axles do. The Rover axles are stronger than most folks give them credit for. That said, it can happen. Really depends on the driver more than anything.
Old Mar 28, 2021 | 11:05 AM
cvhyatt's Avatar
I talked to Bill at GBR when I bought the new diffs (4.11 gears abs truetracs) from him. He said he would sell me HD axles but said they were unneeded unless I had as towing or doing extreme off roading.
Old Mar 28, 2021 | 12:28 PM
whowa004's Avatar
just be careful with the skinny pedal. shock loading is what breaks things - ie spinning tires and then they grab. I haven't upgraded and don't plan to until/unless I break one.
Old Mar 28, 2021 | 03:16 PM
The_OGCJR's Avatar
Bill at GBR advised me that I do not need HD axles when I bought my true tracs and 4.40 diffs from him.
he said he only seen them break when people have air lockers, and off road like maniacs (heavy right foot, going to fast etc)
I’m even going to 35’s and he said I’d be fine.
Old Mar 28, 2021 | 06:29 PM
cvhyatt's Avatar
how are you going to 35”s without cutting panels?
Old Mar 29, 2021 | 07:30 AM
The_OGCJR's Avatar
Ill cut panels if needed.
Old Mar 29, 2021 | 09:00 AM
whowa004's Avatar
Honestly I'm more worried about trutracs breaking axles than air lockers as they require some spinning or slippage to engage vs total control of knowing when you're locked or not. Also if I lock my rear it's right at the obstacle and unlocked immediately once through it.
Kelbird
May 29, 2017 08:11 PM
Shiftonthefly1
Nov 13, 2014 11:55 PM
TRIARII
May 10, 2014 01:56 PM
03rangeroverowner
Nov 2, 2013 11:49 AM
GROVERtheROVER
Aug 29, 2011 09:37 PM
