Back Gate (door) stuck in closed position...
When I bought my Disco I had to turn the key to unlock as I pulled the handle to open the door. I dealt with it for several months until one day I tried it and it would not open from the outside or the inside. I had to remove the sub woofers and the rear panel to expose the door latch. I could reach in and push on one of the levers while pulling on the door handle and the door would open. I found that the small spring in the latch had broken. I ordered 3 from the guy in England that sells them on eBay and replaced it myself. Not too difficult, just take a close up picture with your digital camera for use when reassembling and take your time taking everything apart so you don't break any of the plastic fastners on the rods. The hardest part was wiggling the latch assembly out and back into the door. If the lube doesn't work the spring is broken.
thanks guys...popped the emblem off and used some wd-40( ok right?) and the handle loosened right up...easy fix...i will go back and spray those other areas today...
another question, in one of the posts it speaks of a key hole for the rear door cargo...am i missing something? , i cant find one on my 01, but i agree it must be there, correct?..little help?
I have an 00 Disco that has no key hole so I'm pretty sure you don't either. Great advice guys (I have the same problem but it seems to be a spring issue for me). Along the same topic; my passenger side rear door won't open. The lock head moves up and down and when you pull the handle from the inside you can hear the actuator moving. Nothing heard from the outside when you pull the handle. Any hinys?
for those reading this thread later who might have this problem, if lube doesn't fix it you may want to pop off the interior panel on the rear door and see if anything has become disconnected.
While installing my rear access ladder i somehow knocked a little clip connected to the door handle. After seeing it, it was easily re-attached and working again.
Thank You... Thank You :)
OMG... for mtn's I've lived with my door not opening, and in 5 min. you helped me fix this. I can't believe it. I was going to pay someone like I don't know how much to fix it and my 13 yr old kid did it. Like I said in 5 min. Crazy... I just want to thank you so much for your post. Awsome... Awsome!!!!!!! Thank you again.
leddifer
03-18-2011 09:56 AM
