Rear Door Stuck Closed!
Old Sep 6, 2007 | 07:28 PM
Dahne23's Avatar
Default Rear Door Stuck Closed!
My rear door is stuck closed, it will not open from inside the truck or outside????
Ahh help! What should i look for? should i take the door apart, maybe the pull cable?
thanks this is my first post..2003 Se
Old Sep 6, 2007 | 09:19 PM
okdiscoguy's Avatar
Default RE: Rear Door Stuck Closed!
spray lube in the handle. Put pressure on it and try to "Flip" it back. It isn't returned all the way....My handle gets stuck every now and then, have to keep it lubed and clean as it tends to get dirty and get stuck.
Old Sep 6, 2007 | 09:22 PM
chargersfan's Avatar
Mine gets stuck also, I have to put the key in, turn and open.
Brian
Old Sep 7, 2007 | 07:31 AM
Common problem for Rovers. Pull the Rover emblym off the rear door handle and spray it good with water, let it dry, spray a litle lube on the parts and the start working the handle, it will start opening again.
Old Sep 7, 2007 | 08:41 AM
Dahne23's Avatar
thanks guys! im going to work on this today!
94svt50
Aug 3, 2015 02:31 PM
ImQuattro
May 1, 2014 08:36 PM
seamuspg
Mar 4, 2012 06:24 PM
leddifer
Mar 18, 2011 08:56 AM
kbryant31
Feb 6, 2008 08:02 PM
