Backseat Window Will Not Go Up
Old Jan 15, 2020 | 08:24 PM
Bailey123's Avatar
Default Backseat Window Will Not Go Up
I have a 2001 Disco II. My rear passenger seat window went down, but will not go up. I do not hear the motor when I press the button. I suspect that I just need to replace the motor. Let me know if you had similar experience and if my assumption is correct. Thank you
Old Jan 16, 2020 | 09:34 AM
boston4's Avatar
Did you try using both the center console switch and the rear switch? Sometimes the switch can go or get gummed up but I believe typically it's the motor (pretty cheap on eBay).
Old Jan 16, 2020 | 11:02 AM
Bom2oo2's Avatar
I had a similar case once, window went down & didn’t want to come up, in my case it was not the motor,
it was the center console switch that was bad, so b4 trying to replace motor, swap the switch with the other window that works to see if it’s only the switch that is bad.
Old Jan 16, 2020 | 11:14 AM
Sixpack577's Avatar
Plastic wheels on the regulator will also break off, and then bind the regulator, preventing it from moving up or down.
Old Jan 20, 2020 | 10:01 AM
777AIA's Avatar
On my LR3 you have to hold up/down switch for 2-3 min to get switch to reset, then it will work. Can we do these on the older Disco’s (now that I’m also driving my new-to-me ‘00 Disco 2)
Old Jan 20, 2020 | 01:23 PM
Bailey123's Avatar
I tried both the front window button and the button on the door. Neither works.
Old Jan 21, 2020 | 02:16 PM
Bom2oo2's Avatar
If the center console button is bad, door button won’t work.
Old Jan 22, 2020 | 02:52 AM
JUKE179r's Avatar
try this. It's the same button as the other rear window at the center console.
Tomzsix
Sep 7, 2019 09:38 PM
mirepoixmatt
Dec 31, 2018 10:37 PM
KingKoopa
Mar 7, 2017 03:50 PM
bcolins
Oct 11, 2008 08:23 PM
JBRIII
Dec 29, 2006 06:02 PM
