Discovery 2 Fuel Cooler Bolts
Old Jan 19, 2020 | 09:48 AM
Markwicker's Avatar
6th Gear
Default Discovery 2 Fuel Cooler Bolts
I have the common coolant leak from the Fuel Cooler so will be replacing the O Rings. However, I have noticed that the bottom two bolts to the cooler are missing so need to purchase replacements. Can anyone assist with the size of the bolts, both upper and lower, so I can purchase replacements . I believe the bottom bolts are a different length to the top.
Old Jan 19, 2020 | 11:57 AM
mollusc's Avatar
Fuel cooler???
Old Jan 19, 2020 | 12:30 PM
PalmettoDisco's Avatar
???Coolant lines to the air intake on the throttle body??? But O-rings?
Coolant O-ring to intake manifold, perhaps?
Oil cooler or transmission cooler?
Old Jan 19, 2020 | 12:35 PM
Best4x4's Avatar
M8/M10 bolts if memory serves me correctly for the Trans cooler/oil cooler support
Old Jan 19, 2020 | 01:10 PM
Markwicker's Avatar
6th Gear
O Rings inside either end of the Fuel Cooler which is bolted onto the inlet manifold. Discovery 2 TD5. I need some bolts that bolt the fuel cooler on.
Old Jan 19, 2020 | 01:30 PM
You should probably have lead with it’s a TD5. Most folks on the forum are North American based so we mainly have the petrol motors
Old Jan 22, 2020 | 08:14 AM
Markwicker's Avatar
6th Gear
Thanks for your reply
LR03NJ
Nov 18, 2016 08:50 PM
evoblade
May 11, 2016 01:42 PM
cybercop
Apr 19, 2016 12:52 AM
Beaulim
May 2, 2014 08:03 PM
stamper620
Apr 8, 2013 11:59 AM
