Bad ABS Sensor replacement
Old Aug 29, 2009 | 03:02 PM
tbesselman's Avatar
Default Bad ABS Sensor replacement
I have a 99 Disco II that has a bad right front Sensor. Does andy one have intrauctions for replacement. I order a new one (it's on it's way) and I'm looking for the intracutions for installation. I've replaced them on my BMW, and that was easy....looking at the Disco, it is looking a bit trickier........
Old Aug 29, 2009 | 03:12 PM
lipadj46's Avatar
I believe you have to remove your rotors and the sensor is connected to the hub via a screw with an allen wrench head. For exact instructions download the Rave CD.
Old Aug 29, 2009 | 05:10 PM
How do you know it is the speed sensor, what fault code do you have? Do you know that a speed sensor fault code can also be caused by a bad hub bearing, warped rotor or squeaky brakes?
KlamathMatt
Apr 17, 2020 05:27 AM
LADEROUTE
Mar 12, 2014 08:58 PM
twaszak
Jun 4, 2011 07:49 AM
nynole
Feb 2, 2009 06:09 PM
