Bad Alternator???
Thanks guys, I have ordered a new crank sensor and should be in tomorrow. By the way I found the problem with my door lock, it had a broken tumbler. I simply took the broken one out and it works fine now.
I was able to crank it last night but it only ran for 10 minutes and cut itself off. Then would not crank again after that. Hopefully the new crank sensor will fix it. I will report back after I install it.
With the money you saved - invest in an Ultra Gauge...
There was a post in the last few days of a chap with a detailed bill from the mechanic, $1471 for about $300 of work, and another $3500 "needed." One goal of most forum members is to not have have truck see the inside of the dealership. Outside the parts department,OK, if you have to.
JumPeR04
12-17-2009 07:57 PM
mgabriel
12-11-2008 11:53 PM
mathis_m1a1
01-09-2007 05:11 PM
