2004 Disco Tapping Noise coming from under car
Old Nov 21, 2011 | 11:50 AM
airmarc's Avatar
4wd High
Default 2004 Disco Tapping Noise coming from under car
I have a 2004 Disco SE 64,000 miles. I have noticed a tapping noise while the car is at idle (at lights, or when stopped) this occurs only after the car is warmed up and I have been driving it for around 20 mins or more. When i accelerate, the tapping noise abruptly stops and the car drives normally and sounds totally normal. The sound seems to be coming from directly under the engine or transmission area. When I peek my head out, it sounds like its coming from directly under me. Any ideas? I have not done the 60k service yet, but plan to soon......
Old Nov 21, 2011 | 12:13 PM
1. Cracked flex plate (connects ring gear to transmission)
There have been a number of posts about this as a solution to one of the "ticks".
Old Nov 21, 2011 | 03:46 PM
Just to make sure, you need to crawl under the truck to confirm the location of the noise while someone else is at the throttle.
If it is towards the front of the engine, but low down, you may also have a broken oil pump ring.
Old Nov 21, 2011 | 08:01 PM
coors's Avatar
I second the "cracked flex-plate". I had symptoms similar to yours, turns out my flex-plate was cracked. Read this thread for more info.
https://landroverforums.com/forum/di...-solved-43687/
Old Nov 21, 2011 | 08:15 PM
I was thinking flex plate or cracked pump, but the goes away when under power seemed to sound like stress on flex plate, oil pump noise changes with speed, not torque. Pix of cracked oil pump.
Attached Thumbnails 2004 Disco Tapping Noise coming from under car-oil-pump.jpg
Old Nov 23, 2011 | 07:39 AM
airmarc's Avatar
4wd High
Thanks everyone! Im going to take it to my rover mechanic after the holiday.
Pieczony
Mar 18, 2020 09:15 AM
rezzrover
May 7, 2013 06:02 PM
kpl1228
Feb 5, 2012 02:47 PM
jcostello
Feb 20, 2007 07:18 PM
jcostello
Oct 27, 2006 03:39 PM
