Bad axle seal, anything else to replace?
Old Jul 8, 2025 | 05:08 AM
DiscoOslo's Avatar
Default Bad axle seal, anything else to replace?
I replaced the front driver axle seal while doing the ball joints this winter. Today I was doing my pre-trip inspection/greasing and found a lot of oil on the lower ball joint and wheel on the same side. Smells like diff fluid, and the diff was noticably low in oil. Really happy I caught it. I am assuming it's the axle seal (new part was a Brit part), but is there anything else I should check, or replace while I am in there?
Old Jul 8, 2025 | 06:30 AM
rikkd's Avatar
Do you have stock or aftermarket axles? I had the same thing with an HD axle from Ashcroft my seals were fine, but the collar on the axle had moved a bit allowing oil to leak out. Still need to remove the axle to see for sure. If the collar moves with any force, or if its not centered then it could be your issue.
Old Jul 8, 2025 | 06:32 AM
DiscoOslo's Avatar
Mine are standard axles so nothing special. I'll give that a look. It won't be before our trip tomorrow, but oh well. It'll save me some money on gas 😅
Old Jul 8, 2025 | 10:38 PM
Harvlr's Avatar
I haven’t needed to do it yet, so I can’t tell you how to do it, but the axle shaft does need to be centred or it will always leak.
Old Jul 9, 2025 | 12:30 AM
rikkd's Avatar
Its not hard to do, just the wheel bearing is a PITA.
Diesel Gypsy
May 17, 2025 12:03 AM
Gnomadf
Aug 17, 2021 07:01 PM
KingKoopa
Feb 27, 2017 04:32 PM
slabrat
Aug 6, 2013 12:20 PM
R_Lefebvre
Jun 9, 2011 07:30 PM
