Need axle seal #
Old May 14, 2025 | 12:47 PM
Diesel Gypsy's Avatar
Default Need axle seal #
I have a front axle seal leaking and I need a part number to look for a replacement. Does anyone have a part number for this?
It is a 2000 Disco 2
Old May 14, 2025 | 01:29 PM
CharminULTRA's Avatar
Axle seals are FTC4822. If it's the front pinion seal, it's FTC5258
Old May 14, 2025 | 01:54 PM
Thank you Charmin, it's the axle seals at the wheel end.
What company are these numbers from?
Are the front axle seals the same seals for the rear axle?
Old May 14, 2025 | 07:06 PM
Externet's Avatar
Am also after a rear seal that is allowing axle oil or hub grease to spill onto the brake pads .
I believe it is FTC4919 ----> https://www.jgs4x4.co.uk/discovery-2...ring-oil-seal/ Hope I will not goof ordering this one. 'FTC' seems LandRover part number.
Old May 15, 2025 | 01:24 PM
WaltNYC's Avatar
Front axle.. https://parts.jaguarlandroverclassic...nd/land-rover/
FTC4822
Rear axle... https://parts.jaguarlandroverclassic...nd/land-rover/
actually an o ring FTC4919
Old May 17, 2025 | 12:03 AM
Dervish's Avatar
Anyone got the measurements for the rear, FTC4919.
I never seem to remember to add them to my orders from the uk and I could just get some generic o rings locally.
Broken08
Aug 27, 2023 06:37 PM
The_OGCJR
Jan 27, 2023 07:15 PM
Gnomadf
Aug 17, 2021 07:01 PM
Chris Strecker
Oct 4, 2016 02:44 PM
slabrat
Aug 6, 2013 12:20 PM
