Bad case of Amigos
Old 12-26-2018, 03:02 PM
Friday Night Disco's Avatar
No worries, keep me updated is the codes come back
Old 12-26-2018, 03:28 PM
mln01's Avatar
Originally Posted by earlyrover
_____________________________________________
I had serious issues with Amigos fault codes too, so I did the following work, and have seen NO amigos lights at all for over 50,000 miles, 2004 Discovery:
1. Over the past 50+ years I have done a lot of work with electronic circuity boards, etc., so I am NOT a fan of the shuttle valve circuit board bypass that so many guys seem to like. I would suggest leaving the circuit board as it was originally, and if it is shot, replace it with a good used one; don't bypass it. ...
Earlyrover, you make this statement but you give no supporting rationale. Why are you not a fan of the Option B bypass? All it does is bypass a faulty printed circuit to restore full ABS function. What could possibly be wrong with that?
Old 12-26-2018, 04:50 PM
Best4x4's Avatar
Received 2,297 Likes on 1,688 Posts
Option B is a brilliant fix for a faulty designed internal connection IMHO. The H1 guys get the credit for the mod (H1's have the same WABCO Unit). If done properly with some nice 3M Heatshrink Butt Connectors, Option B is far more bulletproof vs buying another $$$$ WABCO Unit that will end up doing the same thing again! WABCO never re-designed it so the flaw is always going to be a possibility. I think the last WABCO Unit I've ever seen was 2010 so it's 8 years old and once again a 50/50 shot. My 3 D2's that I drive = 2 still going on the OEM internal connection, and 1 on the Option B Mod. It doesn't take any functions away, but it does take the flaw out of the system.
You can do the Option B Mod sneaky and it will be impossible to spot. I however like having the 2pin plug mounted back by the actual ABS Pump for diagnostic purposes when I'm testing various Scantool's for LR ABS Code compatibility.
OffroadFrance
07-09-2021 09:15 AM
KC_Rover
06-12-2019 03:14 PM
KingKoopa
12-18-2017 04:35 PM
Tony C
07-02-2014 03:57 PM
sorbet35
02-24-2012 11:38 AM
Quick Reply: Bad case of Amigos
