Bad steering!
Old Jul 27, 2018 | 03:13 PM
Liam2860's Avatar
Default Bad steering!
Hey I have a 2004 disco 2 with only 125,000km on it and my problem is when I turn the steering wheel it will take a lot of effort then it will ease up for a full turn then tighten back up. The power steering pump isn’t whining or leaking or anything like that. Also the disco was sitting in a parking garage for 2-3 years not being driven. So is it a bad pump or air in the lines???????
Old Jul 27, 2018 | 03:48 PM
The Deputy's Avatar
Lube the two joints on the steering shaft. One is close to the firewall and the other is down by the gearbox.
Brian.
Old Jul 28, 2018 | 12:07 AM
No Doubt's Avatar
Also, check the metal heat shield around your driver side motor mount because it can bend near the metal steering linkage and if they rub then it sort of locks your steering until you put a lot of arm muscle into it.
If you find that, just bend the heat shield away from your steering.
Old Jul 28, 2018 | 10:55 AM
OffroadFrance's Avatar
It sounds suspiciously like an air lock in the PAS fluid. Replace ALL of the PAS fluid as per RAVE using proper PAS fluid, you'll unlikely to need to do it again.
RAVE Page 57-18
Bullykatz
Nov 28, 2021 06:19 AM
JettsRover
May 23, 2017 07:42 AM
Manning
May 13, 2014 11:33 AM
garry hotrod
Oct 13, 2012 02:06 PM
ian11
Freelander
Jun 11, 2011 07:00 AM
