Bad tick in my '04
Strongly suggest to do the oil pressure test. If the pressure is good, then you are good to go. If it isn't, then it's a ticking time bomb that can cost you thousands of $$$$$$. It's not worth the risk.
Get your oil pressure checked.
No it wouldn't tick all the time. Mine only did it under load and never when reving the engine. Sometimes I could hear it on the idle....sometimes I couldn't. Just like yours mine was outside of the cursed VIN range. However......sh1$ happens.
