Bad tick in my '04
Old Jan 11, 2012 | 06:31 PM
  #21
Dave03S's Avatar
The intermittent tick I had that went away when I replaced the SAI pump sounded like it was coming from below the drivers area... But I could only hear it while driving so I was unable to confirm its exact location.
The SAI parts are located on the Passenger side, not the drivers side. At the time of the tick I knew my SAI pump was going because the bearings were screaming every time the SAI pump came on (cold start) however I was short on money at the time and waited till it threw a code before replacing the pump.
One other clue that I forgot to mention before when reporting this was that I could hear the sound of exhaust coming from the SAI pump if i put my head near it and revved the engine with the throttle cable.
My mechanic told me at the time that a failed valve in the SAI system would allow backflow of the exhaust through the pipes going to the valve covers. I suspect my intermittent tick was a backfire through the SAI.
That tick happened from zero to two or three times a day over a few months while the SAI was failing. That tick has not happened once since the replacement, last August
Old Feb 13, 2012 | 12:13 AM
  #22
hhalimi's Avatar
Reading the forum about ticking, found this thread. I have intermittent tick at idle and only when the engine is warm, when cold I have exhaust leak, which I did locate to manifold to pipe gasket, but the SAI making exhuast sound is interesting. Since it hasn't been 8 hours sinse I last drove the car, will wait till tomorrow and listen very carefully to the SAI pump and see if I can hear anything. I did open the SAI pump to replace the filter but the filter was looking pretty good.
Old Jul 19, 2012 | 09:36 PM
  #23
davidmarinadolittle's Avatar
Originally Posted by toad2
I removed the belt but it's still ticking. Has anyone ever had a tappet tick?
I'm going to remove one plug wire at a time and see if it stops. Any suggestions would be welcomed. Thanks
Hi
If itis like mine it is a loose sleeve and makes the engine get hot when it moves up and down touching the head it just sounds like tappets.
It is a work in progress still for me, but it does not look like being able to repair, I have tried the a 2 part product no good, next is to try the old bars leaks??
Regards David
Old Jul 20, 2012 | 08:10 PM
  #24
toad2's Avatar
My tick went away. It really did. I don't like to talk about though, you know, the jinx thing.
1 day I said to my wife " this thing isn't ticking" and she replied "it stopped a few days ago".
Hope it stays gone lol.
xengineguy
Nov 12, 2015 12:23 PM
XCELLER8
Sep 19, 2009 03:27 PM
zracin
Mar 7, 2008 01:17 PM
Kraftyz51
Aug 19, 2007 03:58 PM
97XD
Feb 2, 2007 07:46 PM
