'99 to '02 Discovery engine swap
Old Jul 19, 2012 | 07:53 AM
Shane Hoskins's Avatar
7th Gear
Default '99 to '02 Discovery engine swap
Is anyone familiar with "secondary air injection"? Is this simply an extra belt driven air pump, or is it more complicated than that?
Old Jul 19, 2012 | 08:07 AM
drowssap's Avatar
more complicated than that,
if your swaping engines you can use your heads on the 99 block as long as it came from a DII. If you swap heads you will also be starting off with new head gaskets.
Old Jul 19, 2012 | 08:48 AM
ZGPhoto's Avatar
Secondary air is the biggest PIA POS system. Adds lots of pain to otherwise simple jobs.
Old Jul 20, 2012 | 08:30 AM
7th Gear
Is by-passing the system an option? Couple caps and plugs/or does it have an impact on other electrical systems.
Old Jul 20, 2012 | 08:35 AM
drowssap's Avatar
you need to keep it, is there an issue with it?
Old Jul 20, 2012 | 08:46 AM
So, first, what is wrong with your 02?
How many miles on the 99?
You will find, depending on the conditions of the 02 heads and the overall wear on th 99 block, you will have extra work involved.
How mechanical are you or are you having a shop do the work?
Old Jul 21, 2012 | 09:33 AM
7th Gear
Haven't bought the '02 yet but it alledgedly "has a bad valve and may need a sleeve" is what the owners mechanic told him. My '99 has a bad transmission, 107k miles, and the body is being used on another project. I'm trying to either sell the '99 drivetrain and/or possibly use the motor to fix another one, then sell it. My '99 does not have secondary, but according to the vin, the '02 prospect does.
bennyb43
Dec 11, 2013 08:17 AM
mortishd
Jun 9, 2010 08:47 AM
Wildhorse1966
Apr 3, 2009 12:22 AM
miyadog1
Mar 5, 2009 11:08 PM
Kennyr996
Dec 5, 2007 05:25 PM
