Bad Vibration
Old 03-14-2013, 08:57 AM
samaro71's Avatar
Default Bad Vibration
Hoping someone can help me out here. I have a 2002 Disco II and the truck is vibrating and shaking like crazy over 20 MPH. I checked the drive shafts for play and there isn't any play at all. It does however slam pretty hard when I put it in reverse. Occasionally here some grinding when driving but it isn't consistent at all, comes and goes. Could this be a bad hub, tranny, diff? Any help would be appreciated.
Old 03-14-2013, 09:28 AM
drowssap's Avatar
hold your truck up to the computer, so I can hear it
you have to give us a little more than that to work with.
Old 03-14-2013, 09:36 AM
And look at this flex coupler at end of rear shaft? Motor or tranny mounts? Re-check front prop shaft?
Old 03-14-2013, 12:20 PM
And, STOP driving it before you cause more damage. How mechanical are you?
Old 03-14-2013, 12:44 PM
samaro71's Avatar
I am pretty Mechanical Mike. I don't what how else to explain i other than it feels like I constantly driving over rumble strips
Old 03-14-2013, 03:43 PM
Have you replaced or rebuilt your front drive shaft, or even checked it?
Old 03-14-2013, 04:11 PM
samaro71's Avatar
Not really sure how to check the front drive shaft. Any help would be appreciated.
Old 03-15-2013, 05:29 AM
drowssap's Avatar
these two tech articles will show you what a good a drive shaft and u-joints look like and what is need to rebuild them
https://landroverforums.com/forum/ge...rebuild-29302/
https://landroverforums.com/forum/di...ld-done-30781/
Old 03-15-2013, 11:32 AM
SuperSport's Avatar
Loose Wheel? Sounds like a Major Vibration...
Old 03-17-2013, 01:38 PM
Ron Hiner's Avatar
8th Gear
I got a nasty vibration over 40mph. We checked all the obvious things mentioned here and elsewhere including wheel balance, steering parts, alignment and more.
Turns out one of the wheels was out of round. The way we discovered it was to put the car on a lift and start the engine and run at 40 mph with the wheels spinning - it became visually apparent. I'd like to think there is safer way to test this -- and one that doesn't require a lift.
Quick Reply: Bad Vibration
