Bad Wheel Bearing?
Old Nov 1, 2011 | 04:32 PM
Take THAT, Jeep!'s Avatar
Default Bad Wheel Bearing?
Just noticed yesterday as I was accelerating away from a stoplight that my driver's side front wheel is making odd noises. About 50% of the time when accelerating from a stop it will make a big CLUNK. You can hear it with the windows up and feel it. If I'm going 5mph or less you can hear creakcreakcreakcreakcreakcreakcreak every time the wheel rotates. I've also noticed that when going high speeds (70-80mph) there is more vibration in the steering wheel, ESPECIALLY when it's turned to the left. It's normal to the right, and it vibrates a little when straight. It doesn't really shake, just vibrates. Could this be a bad wheel bearing??
Old Nov 1, 2011 | 06:18 PM
drowssap's Avatar
it would have to be a pretty bad wheel bearing/hub in order for you to hear or feel it. i would also think that if the hub was that bad it would be tripping an ABC code, just a guess but how about an axle shaft /CV joint.
Old Nov 1, 2011 | 06:22 PM
If you get a rotational noise, yes either it is the brakes dragging or the hub assembly.
What have you checked for so far?
Old Nov 2, 2011 | 07:18 PM
I haven't checked anything yet, I just wanted some possibilities. When its creaking, if I hit the brakes it stops.
stops creaking that is. Of course the car stops
Old Nov 2, 2011 | 07:21 PM
Quit wasting both your time and ours and get out and lift up and inspect the hub and brake on that wheel. If it is the hub and you keep wasting time guessing you can run up a bigger bill when the hub lets go.
Old Nov 3, 2011 | 08:48 PM
I'll do that. If I'm not mistaken, if the hub is bad, the wheel will wiggle back and forth?
TheWhiteRover
Aug 16, 2014 08:20 AM
Disco Fuego
May 14, 2013 04:31 PM
Grlica
May 1, 2013 06:13 PM
csb
Jun 5, 2010 08:27 AM
btp226
Jun 21, 2006 05:35 PM
