Bad wiring?
Old Aug 4, 2011 | 07:44 AM
Jake Mays's Avatar
Default Bad wiring?
Hey everyone,
My window went up (as in broke) so I ordered a brand new motor and regulator. Before installing everything inside the door, I plugged the motor in to test it and nothing happened. I also checked the switches which were good. When I press the button to put the window down, nothing happens, however I do hear a click somewhere inside the dash, which means something is working somewhere...right?
I feel like the wiring is bad somewhere...is there any way I can get into the vast rainbow sea of wires throughout this truck?
ANY help, tips, or info would be hugely appreciated.
Old Aug 4, 2011 | 03:11 PM
RAVE manual package download has electrical troubleshooting guide, which is very complete on most electrical things.
Old Aug 30, 2011 | 07:24 PM
jcyrus's Avatar
6th Gear
I have the same issue let me know if you figure anything out
Old Aug 30, 2011 | 08:33 PM
It's the ____ wire, on page ____ of the RAVE. Go directly to the dealer, do not pass GO, and pay the $200 evaluation, shop supply, and chewing gum recyling fee.... RTMFB
Old Aug 31, 2011 | 09:29 PM
jcyrus's Avatar
6th Gear
Check the flexible rubber boot in the door jamb I had a broken wire and it gave me the exact same issue I could hear it click at the bcm but nothing else. I spliced it together and its good as new. Go over it thoroughly, I missed it the first time I looked. good luck
Broken08
Apr 14, 2015 09:46 AM
dparham
Apr 22, 2013 04:03 PM
starcraft1
Nov 13, 2011 08:14 PM
oljohnboy
Sep 14, 2009 03:01 PM
Bene
ROAMING WITH FRIENDS
May 11, 2005 04:33 AM
