Baffling Issue with Flickering Climate Control Illumination
Old Sep 15, 2023 | 08:00 PM
acg's Avatar
acg
Default Baffling Issue with Flickering Climate Control Illumination
I am chasing down a climate control illumination issue.
When the headlights are turned on, the climate control illumination flickers. I changed to a spare climate control unit, the flickering still occurs.
Side note: I installed a new 150 am alternator a few months ago. The voltage registers 13.5V and above. Plus, all other lights and electrical functions are working fine. You can see the flickering in the first 5 seconds on this video.
I also checked the interior and engine bay fuse box diagrams. There does not appear to be a specific fuse glade for the climate control unit? This is what I used for reference:
https://fuse-box.info/land-rover/lan...998-2004-fuses
I searched the forums and can't find anything definitive on this issue. Can someone point me in the right direction please? Thanks in advance.
Old Sep 16, 2023 | 10:58 AM
JohnZo's Avatar
Maybe check the dimmer for the dash lighting?
Old Sep 18, 2023 | 01:44 PM
L33DiscoII's Avatar
I suspect the LEDs are going bad. For $45 you can get a new control panel on ebay. If it doesn't fix the problem, you have a spare or can resell it for $45.
KevinD2
Aug 6, 2023 09:38 AM
Anthony Frantzis
Dec 22, 2018 04:18 PM
gulfstream69xr7
May 3, 2017 07:27 AM
ronguiteau
May 21, 2010 11:45 AM
