Barrs stopped my leaks but stole my heat
Old Dec 4, 2008 | 03:10 PM
foreverdisco's Avatar
3rd Gear
Default Barrs stopped my leaks but stole my heat
My 2001 Disco II was leaking coolant like crazy. Used Barrs leaks are gone but so is the heat. I've blown out the heater core so I'm fairly certain that it's not clogged. The engine temp is in normal range so T/sat seems to be working. All radiator hoses are seem to be normal (too hot to touch) except the two hoses entering and leaving the heater core? As I understand, from the shop manual, The supply pipe for the heater core comes off the top off motor and I cant see how that could be clogged. Any ideas why I'm not getting hot water to the heater core? Coolant level is fine and I've bled the line. Is it possible that the reservoir can be holding proper levels and the engine still not have enough coolant?
Old Dec 4, 2008 | 06:36 PM
Default RE: Barrs stopped my leaks but stole my heat
One of your heater lines is clogged.
Spencerfitch
Sep 27, 2020 12:17 PM
FlyingZebra34
Apr 22, 2013 12:07 AM
OliveroLR3
Dec 19, 2011 09:19 PM
greenwade
Mar 19, 2010 12:51 PM
dalfier
Jun 18, 2007 06:51 AM
