Basket case lives Its alive
Old Sep 8, 2017 | 12:57 PM
LR03NJ's Avatar
Seems to me that it might be a totally different engine. Looks like a 4.0 engine
Old Sep 8, 2017 | 04:32 PM
04in719's Avatar
x2 on not original engine.
I'm pretty sure that is a Range Rover fan.
If I'm not mistaken the 4.6 has a slightly larger diameter air intake hose and throttle body.
Old Sep 9, 2017 | 10:34 AM
abran's Avatar
That's a P38 t stat.
Old Sep 9, 2017 | 03:16 PM
earnies2's Avatar
Default 4.o or 4.6
How can you tell the difference the motor came with 2 intake plenums with different throttle body numbers on them and there was no power steering pump i thought that was odd
Old Sep 9, 2017 | 03:19 PM
earnies2's Avatar
Default Range rover fan
My D2 has the same fan i will check on the diameter of the 2 intakes i got with it
Old Sep 9, 2017 | 03:27 PM
earnies2's Avatar
Default P38 thermostat
If that is a p38 stat than there is a possibility that this motor came out of a p38 would it be possible to have a p38 without power steering and did they come with 4.0 and 4,6 motors
Old Sep 9, 2017 | 03:32 PM
earnies2's Avatar
I just looked up a 2002 range rover thermostat and that is what it is....now how do i tell if it is a 4.0 or 4.6 and without power steering?????
Old Sep 9, 2017 | 09:17 PM
LR03NJ's Avatar
Identifying GEMS vs. BOSCH Engine in a Land Rover
Applies To:
Discovery I | '94-'99
Discovery Series II | '99-'04
Range Rover 4.0 (P38) | '95-'02
Range Rover 4.6 (P38) | '95-'02
Old Sep 10, 2017 | 11:42 AM
earnies2's Avatar
i definitely have a Bosch engine how can you tell a 4.0 from a 4.6
Old Sep 10, 2017 | 12:03 PM
Dave03S's Avatar
There may be other ways to tell, but engine ID is stamped on the block underneath one of the heads. Of course you would have to look next time you have the heads off.
I'm sure someone here knows of an easier way to tell.
