Battery?
Old Sep 30, 2016 | 12:28 PM
velija's Avatar
Default Battery?
A 2002 disco
Didn't start it for two weeks
When I started it I ran it for about 20 seconds and then turned if to check the fluids
Fluids were ok went back to turn it on and nothing absolutely nothing not even light on dashboard
Battery was dead
Hooked it up to a charger for about 5 min and it fired right up
The battery is about 2 months old
Now it fires just fine
Hmm any thoughts??!
Old Sep 30, 2016 | 01:31 PM
velija's Avatar
Crap it happened again
My ultra gauge says it's charging at 13.7 volt
Not even at 2500 rpm it won't charge over 14 volts
Old Sep 30, 2016 | 01:32 PM
velija's Avatar
Could it be the alternator???
Old Sep 30, 2016 | 01:36 PM
Red5's Avatar
Check your battery connections. Sounds more like a cable issue than a dead battery.
Unlikely a 2 month old unit will go from completely dead to clean start with only a 5 min charge. Probably just improved a weak connection when you connected the charger.
Old Sep 30, 2016 | 02:43 PM
velija's Avatar
Yes yes
Just cleaned the connectors fires right up
But still charges only at 13.8 13.9 volts
What's up with that
And thinking about it now that's what it always did
I thought it should be over 14v or am I mistaken
Thanks a lot
Old Sep 30, 2016 | 02:47 PM
Red5's Avatar
This is normal. The regulator on the alternator will vary the output depending on demand.
Mine varies between 13.7 and 14.3.
nateandnikki
Jul 2, 2013 06:38 AM
xoo00oox
Jan 11, 2013 06:23 AM
arrkerr
Dec 14, 2005 10:06 AM
Dhwright
Jun 11, 2005 12:23 AM
robdis96
Jan 30, 2005 08:45 PM
