Battery Drain
Old Nov 8, 2025 | 11:13 AM
RizzleKicks's Avatar
Default Battery Drain
Evening ,
Slight problem, if I don’t drive my 2004 TD5 after 3 weeks it will fail to start as battery has drained totally.
Now got a few queries.
I was told it could be the radio draining the battery can this be a possibility ? Once the car is turned off the radio does not turn in so I do t think that could be the issue & would it draw enough power to drain b battery after 3 weeks ?
Also when I bought the Disco in 2021 it came fitted with a Rimmer Bro box as per attached. This gives it better HP & supposed to help with the performance.
You can see the red cable is wired to the live , would this always be live & could this cause the premature battery drain that I’m getting ?
Any advice would be very much appreciated.
TIA
Old Nov 8, 2025 | 06:18 PM
Extinct's Avatar
Typically it is the ABS system draining the battery, you can either pull the fuse semicolon wire and some relays to power it down; or connect it to a trickle charger or solar charger.
Old Nov 9, 2025 | 09:46 AM
Thanks for the reply. Just to confirm when you mean disconnect, just remove from the white plug & remove red wire from the live feed ?
Hovdebo
Nov 19, 2024 06:11 PM
ZEngineer
LR2
34
Oct 7, 2024 11:14 AM
Dadad
Jan 21, 2020 08:17 AM
roppy5
Range Rover L405 (Fourth Gen)
Jun 17, 2019 06:34 PM
NENYMA
LR2
Feb 2, 2016 06:20 PM
