Battery drain issue!
Old Dec 22, 2018 | 10:32 PM
Blanco.se7's Avatar
Default Battery drain issue!
I’ve read a few threads about battery drain issues, and can’t find anything that’s a physical fix... basically my battery was being stable for about 3 months after replacing it, and one day I was washin my DII and it wouldn’t start after washing it. I know it wasn’t the battery, because I tested it and charged it multiple times, so I went thru the fuses, and unplugged some until the battery stopped draining, turns out the one that was for just the front A/C and heating system was the one draining the battery. Well with it being Colorado in the winter I NEED the heater and if I plug it back it, boom it drains, need help and need to find a fix ASAP!
Old Dec 23, 2018 | 01:24 AM
Frank4's Avatar
Honestly the least frustrating route is to keep it on a trickle charger. Only fix that I’ve ever read.
Old Dec 24, 2018 | 02:22 PM
Blanco.se7's Avatar
hm, it’s frustrating because I can’t leave it on a trickle at school 😂
Old Dec 24, 2018 | 06:16 PM
FlyingZebra34's Avatar
If the heater circuit is draining the battery, maybe the blower motor resistor is faulty? Worth a look.
Old Dec 28, 2018 | 06:38 PM
akapeller's Avatar
I had a persistent drain that was proving impossible to find. After lots of headaches and failed attempts at a true fix, I finally bit the bullet and bought a Battery Brain ( https://www.batterybrain.eu/our-products/ ). Should have done it after the first failed attempt. Easy to install, easy to use, and hasn't failed me yet. I haven't forgotten to manually disconnect when I leave so I haven't personally tested the auto-disconnect. Living in Wyoming with cold 8 month winters makes it easier to justify. I know my battery will start in the morning, no matter how long since I've last driven! Only downsides are resetting the clock/ect, and having the security system disabled when the car is off, but a thief could not steal the car without removing the brain and reconnecting the battery normally, as well as enter the security code when (if!) they finally get it reconnected. So in my mind I just traded my alarm system for a safer hard disconnect (when was the last time you called the cops when you heard a car alarm?). The final downside, you have to know and enter your code every time you reconnect the battery.
That said, having used it for ~8 months now, the added steps are just part of my routine and i barely notice them. All my missing stress of an electrical drain, however, is definitely noticed!
Old Dec 28, 2018 | 08:02 PM
Blanco.se7's Avatar
appreciate the input! How long have you been able to park it in lots before it drains? (I have school so I need it to last 8hours)
Blanco.se7's Avatar
how would I check this?
Old Dec 29, 2018 | 08:06 AM
CollieRover's Avatar
Maybe find a used A/C Control ECU fornthe dash from a breaker? Also, if you google Land Rover Discovery II A/C heater control Test or look in the Rave the system has a self diagnosis function. It may tell you.
Old Dec 30, 2018 | 12:00 AM
akapeller's Avatar
Since it's a battery disconnect your battery should last about as long as it would in storage (about 2-3% discharge per month). I live in a small town and go weeks without driving it, even in the dead of winter. If your battery isn't shot than 8 hours shouldn't be any problem at all. If you decide to get one let me know and I'll send you a picture of my set up. If your positive battery lead is as short as mine it's a bit of a puzzle to get it connected.
abran
Feb 28, 2025 12:02 AM
roppy5
Range Rover L405 (Fourth Gen)
Jun 17, 2019 06:34 PM
longtrip68
Feb 5, 2019 10:26 AM
escott16
Jan 10, 2019 06:09 AM
FlyingZebra34
Dec 21, 2018 11:29 AM
