Battery Life
Old Jan 15, 2008 | 01:34 PM
yarddawg's Avatar
Default Battery Life
Anybody have any idea how much battery power is drawn when a Disco II is parked and not being used?
I've gone about 8-10 days since I drove it last and my battery is currently dead. The battery is only about 6-8 months old too.
Thanks.
Old Jan 15, 2008 | 01:53 PM
spoon's Avatar
Default RE: Battery Life
You have a short circuit somewheres. Have you any aftermarked electronics installed? If so, try removing the fuse of that particular device. If your battery stops draining, then you've found your problem... poor man's style. May I ask why your battery was replaced 6-8mos ago in the first place?
As far as your battery goes, take the battery out and charge it. Get out your voltmeter. A fully charged battery should read 12.6v.Try to remember that your alternator isdesigned to maintain a battery's charge, not to recharge adead battery. I'd hate you see you wreck your alternatordealing with this problem.
Old Jan 15, 2008 | 02:37 PM
Landzu's Avatar
One thing I have heard is that the CD changerstill will have a draw withthe keyoff if that is the last thing used.
When I turn mine offI make sure that I use the radio last.
But you could have a bad battery.
Take it back and have it load tested.
Old Jan 15, 2008 | 02:39 PM
spoon's Avatar
Actually, do you have an ammeter handy? If so, remove the positive (+) battery cable from the battery terminal. Connect the ammeter in series between the positive battery terminal and teh positive battery cable. This test will tell you exactly how much drain you have on your battery. Compare your numbers with others on the forum, hopefully some guys respond with their answers.
What you can do if you find that you have an abnormally high amount of draw, is leave your ammeter attached while removing and replacingfuses one by one. If when you remove a particular fuse the amount of draw reduces to a normal level, you have then found the circuit which contains your problem.
EDIT: Make absolutely sure your battery is good. Like Landzu said, take her down to the local auto parts haus and have her checked out.
Old Jan 15, 2008 | 02:44 PM
yarddawg's Avatar
Thanks for the input.
I replaced the battery 6-8 months ago because it was simply too old... it was time.
It's a Die Hard... so I'll head over to Sears to get it checked.
Old Jan 15, 2008 | 05:47 PM
Have Sears do a battery and alternator draw terst and get back to us.
Old Jan 15, 2008 | 06:41 PM
Disco2Guy's Avatar
I was in Hawaii for 10 days over Christmas and came home to a dead battery. It's a DieHard from Sears I believe. I don't use the cd changer. The only thing different is that I had a Y adapter plugged into the outlet by the shifter, but both my iPod and GPS were with me on the trip. Now they are in the pocket of some a$$hole. Anyways, I'll try to have it looked at this weekend too.
Old Jan 15, 2008 | 07:29 PM
yarddawg's Avatar
I'll take it to Sears as soon as I get my vehicle back and report back to you all. It's currently getting a new door from a hit and run accident on New Years Eve.
Old Jan 15, 2008 | 07:40 PM
Remember that the clock is on all the time. Although it draws a small amount of amps, it is still drawing amps.
And depending on the ambiant temp and how long it was running before you parked it. For example, if you started it and moved it from the driveway to the garage and then shut it back off, the battery wasnt full to begin with.
1ozeme
May 17, 2010 03:22 PM
Mountain_Rover
May 11, 2009 11:44 PM
Cannondale96
Feb 26, 2006 12:45 AM
Patrick
Off Topic
Mar 29, 2005 06:04 PM
amdhotprocessor
Dec 22, 2004 02:03 PM
